I Just created a structure in staad in which there are no errors. I have done analysis. But after imported it to Rcdc but in which some columns are missing i don't know why i checked it's properties, supports etc.
Kindly share your STAAD file for further investigation from our end.
Thanks.
Can you specify which particular column you found to be missing.
I have checked from my end and found that all columns are read in the RCDC file.
RCDC reads the column depending upon the start and end node of the member from STAAD and determines the levels from Y coordinate of the nodes of the column.
Refer below snips for reference. All the columns are correctly identified in RCDC. Let me know if some more clarifications is required.
