I have a couple of error with Punching check not at column Type. How can I fix this and what should I be looking at?
This tends to happen when columns move after the punching checks are created. Go to the layer - design strip - punching shear checks plan. Delete the punching shear check (circle) that is misplaced, and then add a new one.
