This appears when I try to run the Staad Pro and I dont know what to do, someone help please.
Based on the screenshot it appears the error is related to the product, rather then to the license.
Please post your question in the STAAD forum here: https://communities.bentley.com/products/ram-staad/f/ram-staad-forum#pifragment-25818=1
There is also a wiki dedicated to STAAD.Pro, which you can browse here: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/2729/staad-pro
If you are a SELECT user, you can also log a service request at the Service Request Manager for technical support- https://apps.bentley.com/srmanager
Try to rename folder 'STAAD.Pro CONNECT Edition' into 'STAAD.Pro CONNECT Edition_1' in the folder C:\Users\User_Name\AppData\Local\Bentley\Engineering\ and see if this solves the issue.
Didn´t work :(
Have you tried restarting the machine and running STAAD.Pro?
Yes but the error still appears
