This appears when I try to run the Staad Pro and I dont know what to do, someone help please.
Right-click on STAAD.Pro icon and select the option 'run as administrator'; does this help?
If not, uninstall STAAD.Pro, delete the folder STAAD.Pro CONNECT Edition from the machine and reinstall STAAD.Pro.
If you are not using the latest one (Version:22.07.00.160), and you are current in select, download and install the latest version. While installing right-click on the file and select 'run as administrator'; though you may be the administrator for the machine.
