Dear All,
I am performing beam analysis result and getting difference in max moment value and reinforcement detail when analyzing is performed using Track 0 and Track 1&2. Kindly look into the case and help me to resolve it.
Query 1 - In Beam no 36 analysis, max moment is coming at section 5 m is 483 KN-m when checked in post-processing mode and at same beam it is coming max at section 4.17m ( 467.58 Kn-m) when checked in output viewer using Track 1.
P.S. - Max moment value is observed at Load Combination 3 in both the cases.
Query 2 - At same beam i.e Beam no 36, at sec 5 m, reinforcement is coming (3 -25D) and at sec 4.17 m reinforcement is coming ( 5-25D) at bottom face. however, as per my understanding max reinforcement should come at section 5m.
I just wanna ask about Comparison of results on the Design of Beams using STAAD and Manual Calculation, but on the number of bars from manual computation and STAAD has different results. What could be the reason why i get different results? or any factors?
