Iam using STAAD CONNECT Version 22.07.00.160. Please see the below snip from my STAAD Connect edition window.
The resolution is too small in working graphics window to work with modelling and others, but the text inside the member properties dialogue box is too big to read.
Can you please help me fix this issue. Iam having both STAAD V8i and connect edition simultaneously installed since Iam still in the learning curve for connect edition. V8i is working perfectly with no graphic issues.
I tried to manually override the DPI setting to system (enhanced) from application, see 2nd snip below. though it works for the time being, the drop downs in sub menus are not working properly.
kindly help to fix this issue. with thanks and regards
prince samson
STAAD.Pro is defined to operate with the generic windows setup. Have you modified one or more of the settings in windows display scale and layout?
hey Payel,
I havent modified any of the scale or layout. I double checked, it is in default.
can you tell, if there is any reset feature or something ?
Is this a Windows 7 or 10 machine?
Payel,
Its windows 10 OS. If you observed the snip I posted above, the beam members are too small, but the text size inside the dialogue box is too huge. Just in case if the Windows display is changed, shouldnt all the items inside STAAD window should be the same ?
Hello Prince,
From my previous experience, I have seen similar cases when the display resolution is too high. If possible can you plesae check the display resolution set at your end. Also, if possible can you please match the same with below values.
Once set then restart STAAD.Pro and check if this helps.
Please note we have a feature in our wishlist to support STAAD,Pro for higher resolution monitor.
