I keep getting this warning in my analysis output.
"WARNING: The current units are in KN METE. All the design results are in KN MET (unless otherwise noted)."
Could I request some guidance on how this can be resolved?
Thank you
Can you please add the file here?
These warnings are showing up in all my models. A colleague also reported the issue. This is likely a bug in the new version 22.07.00.160.
I have not seen such warning in any of my files. May be it is a machine specific issue. can you please raise a service request so that we can take remote of your system and do the troubleshooting?
You may go through the attached wiki to know the process of raising SR.
https://communities.bentley.com/products/w/products__wiki/24845/service-request-manager
Thanks. Replacing "UNIT METER KN" in input file with "UNIT MET KN" fixes the issue and those warnings do not show up in output. The analysis results apparently not affected. Please check if any changes were made to the syntax in the new 22.07...CONNECT version.
