RAM Steel AISC Verification Question
In the RAM Steel verification document, I noticed that you're using two different equations for the concrete modulus of elasticity Ec.  On page 2, you use the AISC Chapter I equation for stud strength, and on page 5 you use ACI Eqn. 19.2.2.1a for I,effective calculations.  Should you not choose just 1 equation for compatibility?  It appears that the program is doing this as well.
Drew
