How do I go about changing the default size used by Concept when it assigns Program Reinforcement? I have a mat of steel already assigned to my slab, entered as User reinforcement. I'm relying on Concept to tell me what additional steel I need to make the design complete. It's working well, but it's assigning a #5 bar, and I'd like a #7 bar. How do I change the default setting from a #5 to a #7?
Thanks!
The program bar size is defined in the properties of each design strip (CS and MS properties, top and bottom bars). For strips that already exist, just select them all and edit the properties. To set values for your next strip, double click the design strip tool and preset the desired values. You can even save a template to make the default change for future files.
Of course! Thanks for the tip. That solved my problem.
