Load out Ramp.STDError occurring while analysis run. Kindly advise.
This indicates that you have not assigned any Iy value for the member property.
Please use any value may be very small to suppress the warning.
Thank you sir.
The value for IY is 0 only. Also when I was working with older version & putting same input that time analysis was successful. This version is creating errors.
Can you please let me know the version where it was working okay with Iy Zero value?
STAAD.Pro V8i SS6
