Hi All,
I am analyzing the Slab design (S3- one way) with meshing in attached below project. In slab design output, Longitudinal reinforcement in particular element (say element no 614) will be provided parallel to the shorter direction i.e Beam no 39 and transverse reinforcement will be provided parallel to the Longer direction i.e Beam no 613 with respect to Local X and Y axis, However if we consider whole S3 Slab (element no 583 to 732) i.e practical case on site, direction of longitudinal and transverse reinforcement will change as longer and shorter direction of beam will change wrt to Global axis. Hence longitudinal reinforcement pertaining to particular element belongs to Transverse reinforcement for whole slab.Please help us to know how to consider reinforcement in such case ?
Assembly Hall Project 4 with meshing and FL and LC.std
I believe the following Forum discussion should answer your question: Main and Secondary Reinforcement in one-way slab - RAM | STAAD Forum - RAM | STAAD - Bentley Communities
