I am trying to convert my Physical model to the analytical and it is failing at the integrity check. The error message says that members that do no support tapering have been assigned tapered properties. The member the message lists have indeed been assigned tapered properties by mistake in the past. But I went in the "Tapered Members" spreadsheet and deleted the tapered properties for the mentioned members. However, staad still complains about it and doesn't let me create the analytical model.
Is there something else I should do to those members?
Please attach the .std and .stdp files of this model and we will check what is happening.
Modestas, thank you for the reply, but I was in a rush and the only way I found to make it work was to delete all the listed members and re-create them.
Modestas, here you go. 0020.Strucure - Second Version.STDP4314.Strucure - Second Version.STD
I have reported this issue to the development team (HT #722716) for further investigation.
Was this model created in the SPPM from the scratch or you imported it from ISM Repository? Which STAAD.Pro version was used to create this model?
