In the below SKID i need to show that the base frame is mounted directly on the ground. All the ground beams will be layed on the floor and on the 4 cornens i will use 4 fix points How this can be applied on physical
modeler?
Thank you in advance for your support.
Kind Regards,
Select the beams in question and go to Members -> Custom. In the opened dialog, you need to select the support type (Restraints or Springs), provide the amount of segments (the support will be assigned in these segments for each beam) and other information if required.
Good morning Modestas,
Thank you very much for your support.
So this is the applicable way to show and demonstrate the floor establisment in physical and analytical modeler as well?
You need to select the springs in the spreadsheet and it should be highlighted on the model.To edit the model, you need to switch off the Analysis button.
Maybe i didnt explain it correct.
I know that when analysis button is on, i can not do anything in order to modify the model or the spreadsheet.
The problem is when i switch off the button , the relevant values from springs' nodes are dissapeared. Both from model and srpeadsheet. See the 2nd snapshot for your reference.
Please attach that model (.std and .stdp files).
17642- GPSA PHASE 3 EXPANSION (with loads and load combinations for design) angles erased2 with new way of support.stdp.bak17642- GPSA PHASE 3 EXPANSION (with loads and load combinations for design) angles erased2 with new way of support.STD
You need to edit the linear support for whole member. So in your case, select the support of member 2 in the spreadsheet (you may need to change FY from released to spring and provide some spring stiffness). These values will be assigned to all the nodes of this member generated during the analytical model conversion and this will be visible in the Analytical Modeling workflow.Some supports disappear from the spreadsheet, because they represent analytical nodes and once you switch off Analytical button, analytical nodes are not shown anymore.
Answer Verified By: Apostolos Koursaris
