Is Staad Foundation Advanced connect Edition able to design a raft foundation which has beam inside it?
Yes. Beams can be added through the Mat Foundation Job -> Physical beams table
The number of beams is limited to 10,is it possible to add more?
Iam using Staad Pro Connect Edition Update 5,i only see option for slab designer but beam designer is not available whats is wrong?
Yes, more than 10 beams can be added. By default, only 10 rows are shown. To add the eleventh row, click on the last cell of the 10th row and press the Enter key on your keyboard. The 11th row will appear. Similarly, click inside the last cell of the 11th row and press Enter to create the 12th row, and so on.
Beam Designer is available only for the ACI code.
