Hi, iRC FOUNDATION.txtm facing issue of
**ERROR- SPRING TENSION/COMPRESSION SPECIFIED AT A JOINT DIRECTION THATDOES NOT HAVE A SPRING DEFINED. JOINT= 2239 DOF= 2
More over i have assigned the springs as per Figure 5-29: Example for elastic mat generation for a convex polygonal shape
staad input file also attached here.
still i am facing this issue. any solution for this?
Thanks in Advance.
Instead of using Elastic Mat, I would recommend you to use the Plate Mat option. More details can be found here: communities.bentley.com/.../difference-between-elastic-mat-and-plate-mat
Also, the Compression Only support type needs to be selected in the dialog where you select the Plate Mat support type.
