I am struggling to extract axial stress in walls from staad, modeled as plates. Can you assist me in extracting the necessary stresses
You can use the Results Along Line feature to get these stresses. More details can be found in the STAAD.Pro Help section Postprocessing and Reports > P. Postprocessing Workflow > P. Plate Results > P. To display plate results along a cut line.
Can you please clarify with screenshots please, the route does not seem to be available
Click on the Contents button and then go to the suggested section.
