I made a program for getting static check results. The program is
Sub StaticCheck()
Set objOpenSTAAD = GetObject(, "StaadPro.OpenSTAAD")Dim Load_Count As LongDim Loads() As LongLoad_Count = objOpenSTAAD.Load.GetPrimaryLoadCaseCountReDim Loads(Load_Count - 1) As LongobjOpenSTAAD.Load.GetPrimaryLoadCaseNumbers LoadsDim sForces(0 To 5) As DoubleDim sReactions(0 To 5) As DoubleFor i = 0 To Load_Count - 1 objOpenSTAAD.Output.GetStaticCheckResult Loads(i), sForces, sReactions Cells(2 * i + 2, 1).Value = Loads(i) For count = 0 To 5 Cells(2 * i + 2, count + 2).Value = sForces(count) Cells(2 * i + 3, count + 2).Value = sReactions(count) Next countNext iSet objOpenSTAAD = NothingEnd Sub
That is for repeat load we are getting output, but case with wind load we are not getting output
A bug has already been posted for this issue. BUG ID is 488109
