Every time I open RAM elements I get a pop-up for a materials database integrity. It says "Folder "user" already exists in "C:\Program Files\Bentley\Engineering\RAM Elements\Database\Materials\". The folder was ignored"
However, I still have a user folder set up when I open the materials database. Not sure how to fix this and get rid of the pop-up.
Check that the folder setup is correct under File (backstage menu) Settings - General Configuration - User folders...
Did the problem start with the latest update 16.05.00.213? If so, what version did you have immediately prior?
I believe the General Configuration is setup correct. It works correctly for sections database, but not for materials database even though I did the same process of adding the user folder from a zip file for both.
I don't suppose the message actually causes any real problem. We would need the full set of database files or control over your PC remotely to tell for sure what causes it.
