Hi Mates,
Could any one please guide me on, Extracting the design results of concrete beam broken in to several segments due to modelling of plates monolithic with beam. The below pictures show all the beams in the model are broken in to small segments like, 300 mm or 0.3 m each. When I go to output report you will sind "n" number of results and extracting the eaxct stell requirement etc. has become a tedious job for me.
There must be some Idea or trick to summarize this in a proper way. I request the community members to kindly help me in this regard.
Thanks !!
I think designing concrete members in the Advanced Concrete Design workflow (RCDC) is a much more convenient way, because the design is performed for a whole physical beam rather than analytical member.
Regrets !! I dont have RCDC, I am looking for a solution in staadPro, Sir.
If you have a STAAD.Pro Advanced license, then Advanced Concrete Design workflow can be used for free in STAAD.Pro.
