I am modeling RAM walls and I keep getting wall gap errors. When I read through the RAM links, it says a wall need to have a gap at one of the ends. Does that apply for wall orthogonal to reach other as well ?
The Wall Gaps feature is just for tilt-up walls. You don't have to have wall gaps assigned, but you can do so, and then the program will automatically offset the end of the wall a tiny amount so that the walls act independently. I can't tell what might be causing your error based on the picture, but send over the file and confirm your verison if needed.
