In previous versions of RAM Elements, I seem to recall the ability to assign steel connections for design using a RAM Connection module. I no longer see that in Elements - is that a program change or an issue with the software version I have installed?
How can I use Elements and Connection to assign and design steel connections?
Sure, see this: https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/9146/enable-or-disable-ram-connection-for-ram-elements
Hi Seth, we followed the gist of that and things working - thank you. To any future users with this same issue: the menus in that thread are a bit out of date, so you might have to poke around a bit. File > Settings > License Configuration > Ram Connection > Start (Ram Elements version 16).
Thanks again!
