My professor gave us a project about Ram concept and I downloaded the student version of Ram concept. I was following his example but It did not let me use the post tension tools. Is there any way I can use the post tension tools?
Check under help - manage license restrictions to see if you can check on the PT options.
It is expired so Is there any way I can activate it?
Is there any follow up response for this? We are also using the Bentley Educational Program and where told that the Post Tensioning module is available however students are receiving the same message about a trial period being over. How can this be enabled for students?
I'm checking with my colleagues in Licensing, but what university are you with so that I can cross check?
Hi Seth, thank you for the quick response. I am with Penn State. We are using the Bentley Educational Program Portal and when I reached out to our rep, he sad that module should be available.
