Dear All,
Please advise on the below issue in the property dialog box for channel profile. as per snap, for the Japanese profile C150x75x6.5, the web thickness is 6.5mm and flange thickness is 10mm. but in the picture view web thickness is mentioned as 10mm. is this have impact in the section classification as per AISC 360-16 table 4.1a & 4.1b.
This is an GUI issue and it represents only the wrong value in member query box. However, it picks the right number from database and calculations are okay. You may use TRACK 2 parameter to see the full detailed calculation and verify it manually.
Thanks!!
