Dear All,
Please note the member capacity shown in the property dialog box is not as per the least capacity value calculated as per AISC 360-16. the design strength value showing in the beam property dialog box is not as per least design strength value. please check and advise. due to this need to have track 2 check for each member to know the least design strength value. we're not able to compare actual vs design capacity directly from the beam property dialog box
Please attach that STAAD.Pro model.
