I receive this error: "Exception[access violation]Raised! Aborting Analysis" when trying to run a model with STAAD Pro Connect. It has a concrete roof deck modeled as plates. When I added the plates this is when the file received the error. It worked before they were added.
One of my co-workers has STAAD Pro V8i and the file will run with no problem.
I have STAAD Pro Connect Edition V22, Update 7 (Version 22.07.00.160)
File is attached:Concrete Roof as Plates.STD
This was a known bug for version 22.10.00.153 and has been fixed against Bug#872540. You can try the file in the latest version 22.12.00.156 where you will find the fix.
Answer Verified By: Scott Peterson
