Plate modeling
Hi there,
I am modeling a circular tank with sloped base slab in STAAD (note the base slab has an opening in the middle and the slope is towards the opening). The internal diameter of the tank is 60m and the height is 6.2m.
To create the geometry, I used the section wizard to create a cone shape for the base slab and also cylinder for the wall. On completion, I merged the prototypes into STAAD Pro and then generated plate mesh for each surface. The problem is that whenever I run the analysis I get this error message: WARNING* PLATE NO. 2411(JOINTS 3257 - 3256 - 3277 - 3278) IS BADLY SHAPED, WARPED, NOT CONVEX, OR NOT NUMBERED COUNTER-CLOCKWISE. Note I get a lot of them and not just one plate.
I looked in the forum and found this solution error message comes. "IS BADLY SHAPED, WARPED, NOT CONVEX OR NOT NUMBERED COUNTER CLOCKWISE". What can i do to solve this?. I have renumbered the plates, checked for duplicate nodes and warped plates as per the solution but still when I run the analysis the error doesn't go away. I have tried generating plate mesh with both polygonal and quadrilateral meshing and I still get the same error. Can anyone help with this please?
This is a screenshot of the model prior to meshing. Thanks.
