A few questions regarding a cable spanning between two pin supports.
I watched a couple helpful videos:
2021-02 (February) SIG Workshop – Structural for APAC:Advanced Cable Analysis in STAAD.Pro
2020-17 (June) SIG Workshop: STAAD Session: Applications of Non-Linear Cable Analysis
In both of these videos he models the catenary cable as a segmented member. Is there any reason for this? Could he have just used a straight member spanning from support to support. Or a straight segmented member spanning from support to support? Was it necessary to model some sort of initial sag? Or is there accuracy gained in segmenting the member?
For a single member cable spanning between two pinned supports I get a converging result when using the advanced solver but not using the basic non-linear solver. Any idea on why that would be? Do I need to use a segmented member or provide some initial sag?
For a two member (2 segments) cable spanning between two pinned supports I get converging results for both, but slightly different results.
Anything on this?
I don't think it necessary to simulate an initial catenary when using the advanced, non-linear method. The program help, section "G.8.2.3 Nonlinear Cable Members for Advanced Cable Analysis" has some other details on why you can get numerical instability.
OK, thanks for the response. If you happen to speak with Mr. Elumalai ask him if there was any reason he did it this way. I assume that it was so he could get it to converge using the Basic Non-linear solver. But maybe there was another reason.
The reason why i modelled the catenary cable as a segmented member is because of a concentrated load that acts in-between the cable that needs to be modeled as a joint load. Further the basic nonlinear cable analysis doesn't use the catenary theory, hence it is recommended to model the cable with some intermediate nodes to capture the intermediate deflection in the cable more accurately. On the contrary the advanced cable analysis uses the true catenary theory, hence the intermediate deflections of the cables are captured more accurately even without the intermediate nodes. So, yes, accuracy is gained in segmenting the member when you use the basic nonlinear cable analysis. But this is not the case for the advanced cable analysis. Also, the reason for using a curved profile cable in my example is to demonstrate the capability of the program in handling such curved profiles in the basic nonlinear cable analysis itself.
For a single member cable spanning between two pinned supports the advanced solver will give you the correct results where-as for the basic solver to give you the correct result you need to segment the cable into two or more.
The Advanced Cable Analysis is more robust as it uses the true catenary cable element.
Hope this answers your queries.
Answer Verified By: RFreund
Thanks!
