A few questions regarding a cable spanning between two pin supports.
I watched a couple helpful videos:
2021-02 (February) SIG Workshop – Structural for APAC:Advanced Cable Analysis in STAAD.Pro
2020-17 (June) SIG Workshop: STAAD Session: Applications of Non-Linear Cable Analysis
In both of these videos he models the catenary cable as a segmented member. Is there any reason for this? Could he have just used a straight member spanning from support to support. Or a straight segmented member spanning from support to support? Was it necessary to model some sort of initial sag? Or is there accuracy gained in segmenting the member?
For a single member cable spanning between two pinned supports I get a converging result when using the advanced solver but not using the basic non-linear solver. Any idea on why that would be? Do I need to use a segmented member or provide some initial sag?
For a two member (2 segments) cable spanning between two pinned supports I get converging results for both, but slightly different results.
Dear Madhun/SethCABLE CAPCAITY.xlsxTL Problem.std
i gone through the June series of cable analysis
i have confusion about STABILITY Command
i have performed multiple analysis with different STABILITY values
how should i get optimum or best stability value i have attached STAAD and results for your ref
kindly help
also please elaborate about segment / how we decide segments while applying point load
Hi Ganesh,
The STABILITY parameter is an artificial stabilizing stiffness matrix value that is added to the global matrix at each translational direction for joints connected to cables and nonlinear trusses. The amount added linearly decreases with each of the Load Steps and finally reaches to zero at the last load step. Since this is a artificial stiffness that doesn't exist in the site, i would suggest to use as small value as possible as this alters the stiffness of the structure. Usually for simple problems like this i start with a value of 1 KN/m. It this doesn't work, then i increase it to 2 then 5 then 10 etc until it works (max 1000). If any value works, i reduce it half way. For example if 5 doesn't work and 10 works, i'll try 7.5. Try to keep this as small as possible as it doesn't exist in the site.
For your model, i would suggest a value of 1 KN/m for the stability command.
Regarding the decision of segments, i would suggest to keep it simple i.e just one node for the point load. TL Problemr.std
So, with STABILITY set to 1 KN/m and with just one node for the point load i got the max deflection of 1593 mm which is slightly more than you got in your spreadsheet for various values of STABILITY.
I checked this with the Advanced cable analysis in STAAD.Pro advanced and got the same results.
Thank You very much
