<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Beam label -WT beams</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/222514/beam-label--wt-beams</link><description>I know WT are from W-shape beams, but is there a way to change how they labelled in Staad Pro?
 Example WT4x9 shows as W8x18 when reviewing model. Unless you double click to check member before it shows W8x18Tee. Also when you create the member for the</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator></channel></rss>
