Illegal Framing Configuration - Beam 42
I am getting an illegal framing configuration on Beam 42 on the lower level of my model. The data check rings up no warnings for the framing condition. However, when i run the beam design i get the error message for Beam 42 located on the diagonal A9 gridline.
Note: this model is for an existing structure, which needs some analysis for new loads so i am trying to keep it as close to the original CDs as possible
I added additional construction grids on all members close to beam 42. I then readjusted the end of beam 42, 91, 90, and 51 to ensure all of them were on the correct attachment point. This did not clear up the error.
I adjusted the original deck orientation, as another forum mentioned that could be the issue but this did not resolve the matter either.
I then proceeded to delete and redraw 42, 90, 91, and 51 with the modified/new deck orientation  but this also did not resolve the matter.
If anyone could provide some insight on how to resolve the matter, i would appreciate it.
   - Original deck orientation
  - Data check
  - new deck layout
Parents Reply Children
