RAM Connection
Hi, i am a new learner of RAM connection. I have used LIMCON for many years. Recently, i tried to import LIMCON file into RAM, the transfer is ok. it is a 230PFC beam splice connection with top&bottom flanges splice+web splice.  Don't know why RAM file has "Shear connection" and "moment connection" design, my forces are V=12kN, M=32kNm, axial tension=2kN. The LIMCON result show a design ratio=0.82, but RAM show failing with ratio=1.5 for "moment connection" design. The splice plate THK are 12mm. I thought the connection should be fine for RAM, but it give a failure result. Both LIMCON and RAM give the weakest part is flange plate tension rupture.
I am new to RAM, not sure how it calculate the connection design. The RAM result for "moment connection" didn't show input shear force, while the  "Shear connection" didn't show input moment force. Seems the moment connection is only designed for top&bottom flanges splice, while shear connection is only designed for web splice.  How RAM design this type of beam splices?
i saw RAM DATA only have "example" for top&bottom flange splice, and another example for web splice only. Do we need to add both together in a RAM connection design? For other connection type also, RAM will add different "category" into one connection design like this? I am quite sure this connection should be "pass", but RAM gave me a "failure" result. Could you help to guide me how i could rectify my input ? Hope could get a reply soon. Thanks
