Hi all, is there a way to apply concentrated member loads as shown in the image below using STAAD? This is a plan view of a cylinder, the blue marks show each beam division and each beam is 1m deep by 0.5m wide. Please advise. Thanks.
ok - I applied it along the local x and z axis of the member like this. This is the load and this is the result I got from it. Is this okay?
I'm guessing I can also apply it to the local x and z of the member as I show in my Dec 1 reply (left side image) above?
Yes, a load can be applied along the local X, Y and Z axes. Attached is a simple file to illustrate this.8358.str2.std
Thanks Kris
