I got an error message below.
When I reopened the file, It came up.
Is there any way to fix this error message?
Let me know.
Double click on the joint number and make sure that the section is supported by the connection.
Did you recently update your RAM Connection? If that is the case, make sure that your custom sections are in the most current database folder: Creating custom Sections, Materials etc. in RAM Elements [TN]
