I am a new Staad Pro user and I need help with assigning material properties. In the physical modeler....I am only able to assign 36ksi and 50ksi steel material properties. What do I need to do to have access to other steel properties for assignment...such as tube steel?
In SPPM under Catalog option there is an option to add material.
From this option you can add any user defined material. The type should be custom. Then you can enter the name you wish and also the properties.
Hope this helps.
Thank you for the reply! Is there a way to load the AISC database so that I have all of the AISC materials without having to load each one individually?
