In the Analysis -> Load Combinations mode when looking at the Member Force Envelope for axial force in vertical bracing, there is only an option to look at either the maxima or minima. I'm looking to print a frame elevation with the absolute worst combination loading, whether it is a max compression or min tension, on the same elevation. Is there a way to view the absolute worst loading on the same frame elevation?
You have to review both min and max. Or you can export the results to Excel and use some Max ASB function. You could also make a double set of load combinations with all reverse load factors I suppose (and then min and max ought to be equal).
Answer Verified By: Michael Duffield
OK. Thanks for the suggestions, Seth. Much appreciated!
Can I make a request to have this feature added for an enhancement to future versions of RAM? It would be very beneficial to be able to look at absolute values in one elevation quickly and easily without any extra steps, for review, comparative model studies, sharing with trade partners, etc.
I can pass it along, or you can add an idea here: https://communities.bentley.com/products/ram-staad/i/ so that others can vote on it.
Great, thanks Seth.
