Punching Check Not Recognized
I am running a floor plate, and one of my columns will not run a column punching check. Normally, if the design check isnt centered on the column, it would say that as an error. However, this comes out as a warning, "No punch cutoff sections found". I have adjusted the search radius and desired sections per zone, but still no luck . Does anyone have any tips on how to get it to properly check?
