76. R1 1.0 77. CHECK SOFT STORY **WARNING - COMMAND REQUIRES SECTION FORCES, HOWEVER NO CASES ARE SOLVED YET. ***STAAD.Pro WARNING*** ANALYSIS NOT PERFORMED - SO ABOVE COMMAND CAN NOT BE PROCESSED
I keep on getting this warning during my initial analysis to avoid errors. Please help me fix this. Thank you.
CF.std
I can see an additional Soft story check in your model. Please delete it and move the selfweight command under reference load R1. The try running the file. Hope this will solve the issue.
7140.CF.std
