I created an MS access file by exporting ETABS ( version 19.1 ) model and analysis results.
But while importing the same to RCDC ( latest) I get the error message ,"Columns are missing ".
Actually I wanted to do the buckling checks for the columns and walls.
Can anyone help me with this issue.
Thank you.
Can you please share the MDB and RCDX file as well the latest version number of RCDC which is installed in your system .
Kindly note that I used ETABS version 19.1.0
Any update?
Can you please send the etabs file at ranjana.shinde@bentley.com.
sent etabs file
