ASCE 7 Generated Wind Loads in STAAD
I am trying to check some STAAD models containing ASCE 7 generated wind loads.  The details of these wind loadings are proving difficult to verify.  If I use STAAD to open the .STD files I was sent, and go into the ASCE 7 wind load dialog box, it appears to contain default values, not the job-specific values that the engineer input.  If I instead review the STAAD input file, I see the do-not-modify wind definition section, but can't interpret all of the parameters that it contains.  So my questions are:
  1. Why doesn't STAAD read the wind definition parameters from .STD files and display them when I review the definition in the GUI?  (Specific example: the model has a basic wind speed of 105 mph. I can see that number in the 1st parameter of the do-not-modify definition in the Input File.  But the GUI dialog box always shows 110 mph.)
  2. Is there a parameter key that I can use to interpret the values contained in the input file definition?  Some of them are obvious, like the basic wind speed.  But most other parameters are not.
Parents Reply Children
