I cannot able to print the detailed design of the Steel Design even after selecting it in the report setup from the output.
Kindly help. Only option I am thinking is to take a photo from my iphone and add it
I am using Staad version 20.07.09.31
The version 20.07.09.31 is very old and we have stopped providing support for those older versions. I would request you to upgrade to the latest version 22.08.00.175 as soon as possible to enjoy all latest updates and codes. However, can you please upload the file for a check. And alternatively you can print the part of .anl file to pdf which is having the detailed calculation in it. Please use TRACK 2 all parameter to print detailed calculation.
Even with latest version of STAAD.Pro CONNECT edition and using TRACK2, I am not able to print the steel design details. I have attached the model.Bus_Support_Design_TBS5_v1.STD
