I have a model but i keep on getting error (Columns are missing) when i run RCDC,i have attached my model.I need your help
8712.Structure2.STD
Dear SirThis is a special type of structure. there are all inclined column present in the structure. RCDC trying to identify at least one vertical column in analysis file.in this case as there are no single vertical column present in structure, it is showing error of column missing.I have created a updated STAAD file with one dummy vertical column. RCDC will read this file and you can proceed with the design. Updated STAAD file is attached file for your working.8712.Structure2_Updated.STD
thank you i managed to run RCDC
