I need Clarification about the difference of the results observed in these two models ,i have attached my two models
1.The first model i created Steel columns ,and below steel column i created a concrete column as observed on attached model ,the design results of these concrete columns are as shown on the attachment
3716.Structure1.STD
Structure1-Column-1.zip
2.The second model i created Steel columns ,and below steel column i didn't put concrete column,i designed my pedestal in RCDC ,the design results of these pedestals are as shown on the attachment
Hello Abhisek M may you help me about this scenario
Request you to also share both the RCDC files.
check on the post ,i attached the Staad file together with RCDC file, for both cases.
