I am modeling a single span steel frame bridge with steel piles and sheet piling, which I input as plates. The W-shapes and HP-shapes are getting utilization rations, but my C-shaped members are getting N/A for utilization ratio in the report output. How do I get a utilization ratio for these channels? See attached model.
F-46 Frame 3D Analysis.STD
The design of channel shapes for bending is not implemented in the STAAD.Pro for AASHTO design code. This is mentioned as a warning in the Output file:
