REGARDING THE RAM CONNECTION WITH BUILT UP SECTION
REQUEST TO RAM TEAM PLEASE CREATE ONE MENU DEDICATED TO BUILT UP SECTION CONNECTION DESIGN.  MANY TIME THE WARNING FOR PRISMATIC SECTIONS APPEAR WHILE ASSIGNING THE REQUIRED CONNECTION. IT WILL BE CLEAR WHICH CONNECTION SUPPORT FOR BUILT UP SECTION.
THANKS YOU ..
  • Hello,
    Thanks for the suggestion. I would request you to post any suggestion in the IDEA tab located at the top of the page.
    However, the help file already has the information for different connections supporting different type of member. You can refer the help file clause 2.3.4 and the tables show all information for all the codes. Please see below snap to understand the help file path.
    Thanks & Regards,
    Abhisek Mandal
    Global Technical Support
