When I design a deep beam in RCDC , it is failng in shear. How can I design it i RCDC.
Can you share your your RCDC File and STAAD file for further investigation.
5621.SAINIK SCHOOL EDIT 5.02.22 single storey.STD
Request you to also share the Design settings that you have made in RCDC File.
Note that I have imported the STAAD model in RCDC for designing beams at 4m level.
If possible, it would be better if you share your RCDC file itself and also mention the RCDC version you are currently using.
Pls check it
Pls share RCDC file / design settings for further checking.
