RAM Connection Concrete Cast Against Earth
I'm designing a post connection to a concrete wall, which is not cast against soil. The design is failing because of minimum concrete cover requirement for "cast against earth" applications. I can't seem to find where to change that setting to indicate otherwise. Could you point me in the right direction?
Parents Reply Children
