Please help to remove this error from Staad.
STAAD SPACESTART JOB INFORMATIONJOB NAME MOULDINGJOB CLIENT DATJOB REV P1JOB PART DESIGN OF MOULDINGENGINEER NAME PPECHECKER NAME PPEAPPROVED NAME PPEENGINEER DATE 28/02/2022CHECKER DATE 28/02/2022APPROVED DATE 28/02/2022END JOB INFORMATIONINPUT WIDTH 79UNIT METER KNJOINT COORDINATES1 0 0 0; 2 0.633001 0 0; 3 0.633001 0 0.452001; 4 0.633001 0 0.892002;5 0 0 0.452001; 6 0 0 0.892002; 7 0 0 1.33; 8 0.633001 0 1.33; 9 0 0 1.777;10 0.633001 0 1.777; 11 0 0 2.61701; 12 0.633001 0 2.61701; 13 0 0 3.13301;14 0.633001 0 3.13301;MEMBER INCIDENCES1 1 2; 2 5 3; 3 6 4; 4 7 8; 5 9 10; 6 11 12; 7 13 14; 8 1 5; 9 5 6; 10 6 7;11 7 9; 12 9 11; 13 11 13; 14 2 3; 15 3 4; 16 4 8; 17 8 10; 18 10 12; 19 12 14;ELEMENT INCIDENCES SHELL20 5 1 2 3; 21 6 5 3 4; 22 7 6 4 8; 23 9 7 8 10; 24 11 9 10 12; 25 13 11 12 14;SUPPORTS4 6 TO 14 PINNEDDEFINE MATERIAL STARTISOTROPIC STEELE 1.99947e+08POISSON 0.3DENSITY 76.8191ALPHA 6.5e-06DAMP 0.03TYPE STEELSTRENGTH RY 1.5 RT 1.2ISOTROPIC STEEL_275_NMM2E 2.04999e+08POISSON 0.3DENSITY 76.9995ALPHA 6.66667e-06DAMP 0.03G 7.88458e+07TYPE STEELSTRENGTH FY 274999 FU 409998 RY 1.5 RT 1.2END DEFINE MATERIALMEMBER PROPERTY INDIAN1 TO 19 TABLE ST TUB1001005CONSTANTSMATERIAL STEEL MEMB 1 TO 19PERFORM ANALYSISCHANGELOAD 6 LOADTYPE None TITLE LIVE LOAD (LL)JOINT LOAD12 FY -2.94LOAD 1 LOADTYPE Dead TITLE LOAD CASE 1SELFWEIGHT Y -1 LIST ALLLOAD 2 LOADTYPE Live TITLE LOAD CASE 2AREA LOAD1 TO 19 ALOAD -4 GYMEMBER LOAD6 CON GY -2.94 0.315 0.0519 CON GY -2.94 0 0.05PERFORM ANALYSIS PRINT ALLPARAMETER 1CODE IS800 LSDPERFORM ANALYSIS PRINT ALLFINISH
You need to delete or comment out the additional perform analysis command as shown below from your file.
Also, you need to define thickness for the plates you have used. I have used 20mm thick steel plate as an example and the attached modified file is running fine.
20836.Structure1.STD
