<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Model Vertical Bracing Column Face - Offset Centre Node vs. Shift Node Coordinates</title><link>https://communities.bentley.com/products/ram-staad/f/ram-staad-forum/226634/model-vertical-bracing-column-face---offset-centre-node-vs-shift-node-coordinates</link><description>I am Modelling an existing building with Vertical Bracing between columns. Due to the presence of infill masonry walls, the bracing is located on the column flanges (not centered on the web)
 Bracing has been modelled offset to column face (see picture</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator></channel></rss>
