Shear demand for Column web panel
While designing Moment Connection with Haunch in RAM Connection, I find the shear demand for column web panel check does not change based on haunch depth. However the demand changes when the beam section size is changed. Can you please explain why is the haunch depth not considered in lever arm for calculating the shear demand?
