*** NOTE: CAPACITY FOR MAXIMUM # 264 LOAD CASES IS ASSIGNED FOR PLATE LOAD.please provide solution of this warning.
Here is an explanation: *** NOTE: CAPACITY FOR MAXIMUM # 266 LOAD CASES IS ASSIGNED FOR PLATE LOAD - RAM | STAAD Wiki - RAM | STAAD - Bentley Communities
I just received this same note. In the explanation from the above link, it is unclear whether my model ran successfully and was analyzed successfully with the note. Is that correct? Or do I need greater memory capacity to run/analyze my model successfully?
If you did not receive any errors, then the model is analyzed successfully and you do not need to worry about this note.
for me load cases values just changed. it does not worked for me.
Please upload the STAAD file here.
180KL-12m Over head tank - Copy.STD
